Futaba Fasst 2.4 10cWhat is the model number of your Futaba
That page tell you exactly where to change it. It's the same manual for heli or airplane version, just like all other Futaba radios. You scroll to the place where it says heli and CHANGE IT TO ACROBATIC.
If you are having so much problem with this basic function, maybe this radio is a bit over your head?
mixing switches for fail safe
I got a problem with mixing just want to make sure that I do not make any mistake first I got WKM with GPS
so in order to mix the second switch with 3 way switch since 3way switch can go to GPS A M but not on the froth one so if i mix the second switch with 3 way switch in order to turn the fail safe Blle in DJI software does the 3 way switch has to be on blue as will as the second switch that set for fail safe in the same time . If some thing happens the GPS bring it home back while it is on fail safe mode too or the GP A an M they do not have to be on blue and only the second switch that set for fail safe has to be in fail safe mode and blue in WKM software
