as an interim project to hold me over until I go to NAB next week, I decided to do what is described by the title of this post. BorisS & redridinghood, I decided to post here because I couldn't figure out how to attach an image to a private message, though I have no problem doing so in a thread...hmm? Here is a repost of the question i sent to each of you via PM:
I was hoping you could help me out a little with my new interim project that I decided to take up between now and NAB, which is that I've decided to slap together some of the many unused electronic components that I have laying around my shop. Specifically, a set of Hoverfly Pro + GPS board, a set of 4 Axi 2218/20s, and to power them, a Herkules II v4 board, which is what I am having problems (I think) with.
I've followed your posts on how to create the micromatch cable to PPM outs with one plug containing the 8th micromatch grounding wire, and then added simply a deans plug to receive power from the 4S Lipo I will use as a flight pack. Then I went ahead and used the programming cable to upload PPM 8Hz 16DEG AFW1 to each of the 4 outputs successfully following the directions on Andreasbaier.de website. Then I taped into the deans power feed a supply for the HFP boards so that they will be able to talk direct voltage measurements from the flight pack.
Once all assembled, I plugged all the motors cables (3each) to the extensions that I soldered well to the Herkules II boards via gold connectors, then used the tap with servo cable to power the flight boards, then attached my receiver to the FC, and finally plugged my flight pack to the finished setup. Well, the Hoverfly boards are getting power as they sound their startup tones and LEDs, and the receiver lights up n connection with my transmitter, but there are no lights on the Herkules boards nor do the motors sound any initializing tones as I expected they would, despite my measuring 16 volts across one of he Mosfets on he Herkules ESC. So that tells me that the Herks are receiving full power, bu I was under the impression there ought to b some type of visual indication tha they are working properly, am I doing something wrong that you are able to identify by my description?
I appreciate you taking the time to help me troubleshoot here, as I think I must b extraordinarily close to having this setup airborne.
Thans again,
Jonathan
Thans again,
Jonathan
