got 1804 motors
Hoki
So these readytosky 1804 motors came in the mail today and it has a part that has the shaft u screw down and it has 4 holes that match up with the motor top and then theres 4 holes on the bottom of the motor 2 of which r spaced the same distance from each other but then the other 2 are spaced a little further apart however all 4 holes still match up to my holes in my arm but the two that are further apart r more near the ends of the holes. But there were only 6 screws all the same size included for each motor but doesnt it need 8? Also it included a disk that has a tiny hole in the center and just two holes 1 on each side kike the shift part. Do i have to put the disk under the shaft when i attach it cause if i dont the screws hit the windings
[url=http://postimg.org/image/6vgn7i9al/] [/URL]
violetwolf
On the smaller motors you can get away with using just two motor mount screws. Lots of racers do that to save weight. So you should be OK
