Gimbal gear ratio theory. Why not using ratios of 2:1 for faster movement?
Hey guys,
right after finishing the modification of the fast Savox brushless servo (0.06s) I am still having problems with the overall speed of my system. I am using the hoverfly gimbal controller with the Savox SB-2271SG. My university project needs to rotate the camera more than 360°. I am wondering why all professional gimbals are using gear ratios of about 1:3 upwards (servo:camera-axis)? (That is the reason why I chose a gear ration of 1:2.6 for the first test.) Is that just for achieving a smooth rotation of the camera? A smaller or "negative" gear ratio ratio would result in a much faster camera-movement. What about using a ratio of 1:1 or 2:1 (servo:camera-axis)? Why is nobody using these sort of gear ratios? Has anyone ever tried one of these ratios?
Help is greatly appreciated. :)
Christian
P.S. I wasn't sure where to post this thread, so I decided to use the general discussion board and this aerial photography board. If anyone knows where it belongs, please remove the wrong one. :)
I started using rc servos with direct drive (1:1) in the first gimbals i built. The result was that they were very unprecise, movement was not smooth and that affected both control and compensation.
With 4/1 and 5/1 (the ratios i use now) the movement, although slower for the same amount of used power, is smooth and precise, it's a matter of resolution that is even more important than torque.
This might turn out in an interesting discussion, i have the idea that 2013 will change many of the things we're used to.
DucktileMedia
Your weakest links are the potentiometers and the backlash from slop in the servo gears. Personally, I would rather have smooth than fast. If you are getting that kind of drastic motion that you really need ultra fast response i think the problem is more in piloting or the heli. But I guess I am not that fussy with my setup as some are. You're not gonna get a Zenmuse from an AV or cinestar. But if you tune everything as well as you can you will get comparable results. I cant wait to see PH Hero's when/if they ever come out. Would also be interesting to see what evolves with linear motor technology although I think someone, probably Denny, answered why they are not ideal for this application but i cant remember. I would stick with the factory reduction ratios.
Hmm, unfortunately I was expecting what you said.
So what would you do to speed up the overall rotation without getting to much of jitters and stuff that makes the final movie unusable? I have a camera, that only needs to rotate around its lens axis and align with the horizon that way. I am already using a servo that is quite fast and strong (0.06s, 20kg).
I read about the PH hero system. It uses direct drives as far as I can see. What kind of motor are they using. Any ideas?
HP
How did you modify the brushless servo for an external potentiometer? I took a look at those servos and figured they weren't worth the work to get them apart.
As for the gear ratios, part of the benefit is that a 5:1 ratio acts as a mechanical filter of sorts in that any backlash or jitter from the servo end is reduced by 80% at the lens. Quality of the pot is relevant also although a cheaper pot will work fine at first before wearing out from so much rapid movement at such a small spot within its range.
for what we're doing with aerial media where smoothness is everything, reducing a .06 sec servo to 5 times that still seems to be well within what the gimbals need to function well.
bart
