GEOCALLA G3-3D
The 3-axis Geocalla G3-3D gimbal is customized for GoPro Series. With a high degree of accuracy and lightweight gimbal system and brings them to the GoPro Hero 3, 3+ and 4 for smooth videos. No need to rely on the flight control systems. It supports various devices like aircrafts, cars and boats. It’s ideal for extreme sports, aerial shots, FPV liker, professional filmmaking and ad shooting.
Geocalla G3-3D Features:
3-axis high performance gimbal
Effortless Setup
Solo used
Totally-enclosed motor, is not affected by iron filings, sand and dust
When charging, change SD card or battery you don't have to remove the camera.
Wide range of voltage, from 23V to 10V
Angle Control support.
Firmware update and parameter adjustment support.
Weight: only 166g
Specifications:
-Supported Camera: GoPro3, GoPro3+ Black and Sliver and GoPro 4
-GCU Input Power: 5S~3S LiPo (23V~10V)
-Gimbal Operating Current: Static current: 100mA (17.4V) / Dynamic current: 300mA (7.4V)
-Gimbal Input Power: 5S~3S LiPo (23V~10V)
-Operating Temperature: 0°C ~ 60°C
-Gimbal Weight: 166g(with GCU)
-Gimbal Dimensions(With Damping Unit): 94mm X 105mm X 90mm
-GCU Weight: 12g
-GCU Dimensions: 44mm X 21.5mm X 9.3mm
-Controlled Angle Accuracy: Tilt/Roll: ±0.05°/ Yaw: ±0.05°
-Controlled Rotation Range: Tilt axis control: -100 ~ +10°
Including:
1. Gimbal X 1
2. Vibration Absorbers 30° X 4
3. Vibration Absorbers 40° X 4
4. Vibration Absorbers 50° X 4
5. Gimbal Control Unit, GCU X 1
6. Camera securing bracket X 2
7. Cup head hex socket screws (M2.5*5) X 8
8. Screw for Gopro4 X 1
Test Video
Geocalla.com
Effortless Setup
Solo used
Weight: only 166g
Specifications:
-GCU Weight: 12g
Including:
1. Gimbal X 1
Test Video
Geocalla.com
