Futaba T8FG channels 13 and 14 how to configer ?
fritz99
Hello !
The Transceiver TG8FG is a 14 channel transceiver.
I can see the 2 channels DG1 and DG2 in the TX configuration menu and assign a switch.
But i do not know how I ca output those two channels on a receiver.
I have configured the 8 channel receiver to output channels 9 to 16.
The channels 9 to 12 are working right.
But the last two channels have no output.
Can anybody explain to me what I have to do, that the channels 13 and 14 are output on the receiver ?
Thank you.
Fritz
PilotMan
Im sure you got this by now..... But Im having a similar issue. I have an sbuss breakout cable that allows me to assign three outputs to three servo's. Problem in on the radio......9 - 14 are all linked together and move together. Im sure Ill figure it out but!!!!!
The only way to get to those DG1 and DG2 channels is through an Sbus decoder. I understand those are technically channels 17 and 18 which is why you don't get them.
I use this HobbyKing decoder, but you can also go with Futaba's decoder, which is much more expensive. Of the links below, one is just the decoder, the other is the decoder plus programmer.
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idproduct=24481
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idproduct=24482
Function assign different AUX channels.
Sent from my SAMSUNG-SGH-I337 using Tapatalk 4 Beta
