Futaba 8FG smooth tilt profile for Phantom 2 malfunctioning.....check Video
xzoticskillz
Anybody have an idea on what's causing this? This is a brand new unit and never flown. Whenever I enable tilt range (from 0-90 on SD switch) and add smooth tilt (medium-slow speed on SA switch) using motor p-mix profile on the 8FG I get the zenmuse become spastic. Is this a defective zenmuse or is something going on in my futaba profile that I'm not aware of. I also notice that it speeds up slightly as the tilt approaches 0 degrees (baseline). Any help would appreciated.
Here's a video showing the problem:
stereo3dguy
That is strange behavior. Did you just upload the profile or follow the pdf instructions. Either way, I would check the End point settings and the and Prog. Mix settings and make sure they match. I've tried to duplicate the problem and am unable to do so.
take it off the sa switch for the smooth tilt and put it on the slider. Then reduce the servo speed of the tilt in the transmitter. mine is very smooth...
