Futaba 6K transmitter with Naza M V2
Issue setting up the Futaba 6K and Naza M V2 flight controller with S.BUS
Has anyone setup S.Bus / D.Bus connection on the Futaba 6K with a Naza M V2 flight controller?
I can not get the Flight Control Mode to come through on any switch/channel.
X1 on the Naza comes into the Futaba on CH5 - I can assign to a 3-way switch but does not control flight modes
X2 on the Naza comes into the Futaba on CH6 - This can only be assigned to the IOC control and works fine on a 3-way switch.
Problem is I can't get the Naza "Control Mode Switch" to show up on the Futaba 6K. Any advice?
DroneTalk
R/C Expert
Staff member
You have to assign a switch also did you try to not use the Sbus and just connect each channel?
Thanks for your reply, Paul. Yes, I can run in the "traditional" mode and connect each channel. That's what I'm doing now, and that the 2 Aux channels out of the NAZA go to CH 5 (flight control mode) on the receiver and TX 3-way switch. The other Aux out of the NAZA goes to CH 6 (IOC) on receiver and TX 3-way switch.
But when I try to switch over to SBus and properly configure CH 5 on the receiver to take the single input connection from the X2 channel on the NAZA I can't get the "flight control mode" to come through on the TX. Can't see it on any of the switches in the Naza Assistant setup. All the other channel work (i.e. roll, pitch, throttle, rudder).
Thanks. Tried that a number of times and confirmed by green light -sbus channel. The control mode switch on the NAZA-M-V2 channel U is not coming through the sbus channel to the receiver and TX 3-way switch.
