Parapyro
Precision Aerial Filmworks
Selling Radian 3 axis Gimbal stabilization modules.Used for 6 months, works perfectly.
Asking $800.00
Included is:
(3x) Radian Stabilization Module
(3x) 100mm male/male servo extension
(1x) Programming board
(1x) Programming cable
(1x) Mounting plate and hardware for roll
(1x) Mounting plate and hardware for tilt
The Freefly Radian Stabilization Module by Freefly Systems is a digital 3-axis stabilization system purpose built for the CineStar 2-axis and 3-axis gimbals. The Freefly Radian gives the camera operator precision control of the camera gimbal and aids in the execution of complex shots. The Freefly Radian combines cutting edge sensors with proprietary algorithms to provide unprecedented stability, control, and reliability.
The system allows for unrestricted stabilized 360-degree panning ability, essentially decoupling the pilot from the camera operator. Never before has the pilot been able to pan the aircraft without upsetting the camera operator's control of the system.
Technical Specifications:
• Pan / Tilt /Roll Stabilized (1 module needed for each function)
• Auto-leveling horizon
• 400Hz update rate
• Adjustable slewing rates for precise control
• S.bus, PPM, PWM, and spektrum input options
• Simple setup and operation
• Small form factor for flexible installation options
• User upgradable firmware
Asking $800.00
Included is:
• 400Hz update rate
