Aerovideo
Bear with me on my FC rant
When I first started out in multirotors I was flying a Gaui 330x like I suspect a lot of people did. I moved that FC to several different frames and it served me well but definitely had its quirks. I then thought I needed accelerometers for safety so I picked up an FY90Q, talk about quirks... YIKES that thing was awful.
I did a lot of searching after that and finally landed on the Hoverly Pro. I've been flying those for quite a while now and have 3 pros (1 dead), a GPS, and 3 sports.
But being adventurous, I finally got a CC3D FC. This thing is TINY! I can fit it into just about anything and the software runs on my Mac... hint, hint, wink, wink. It also has the ability to work with just one cable to the Rx with PPM, SBus, or even a satellite Spektrum rx. It comes with a nice little all in one PWM cable as well for traditional setups. It has both gyros and accelerometers plus you can do simple gimbal stabilization. It doesn't have an OSD though.
Now before you run me out of the Hoverfly section let me just describe my "out of box" experience with this tiny little thing.
I setup my QAV500 frame with the same gear that I had on it when it was controlled by one of my HF sport boards. I went through the setup wizard and went out into the back yard and did some test flights. YIKES!!! This thing was ALL OVER my back yard. It was everything I could do to land it in one piece. WOW, the default settings were terrible.
So off I went to learn about tuning this thing. This is where it gets complicated, PID tuning is not my bag baby and it looks like I'm going to have to learn all about it. Oh how I longed for the simple gain setting in my transmitter as well as the out of the box settings that were at least flyable. I ended up cheating and copied someone else's settings, which we all know doesn't really work but, at least it is flyable now. I have a lot of reading and youtube videos ahead of me.
While I have seen a couple of people get fantastic results out of this thing it looks like it's going to be a LOT of work to get anywhere near what I'm used to.
In conclusion, this tiny little FC is cool, I just wish it was a Hoverfly! Nothing beats the ease of use of a Hoverfly. It's just that the HF board is HUGE! It can be tough to work with on a lot of frames unless you're flying some monster sized hex or octo. I don't suppose a new smaller version of the Pro board is in the works? Maybe about the size of the current sport board even?
I have yet to try a Naza as they seem to be all the rage but all the video I see from those is wobbly. But a nice self contained case does make it seem to be more of a finished product and less hobby looking. Given Hoverfly's high end professional target market I think it would be a pretty good idea to create a nice small FC board with all the features of the pro maybe minus the OSD and put it into a nice fitted case, that would look professional and it would be a lot easier to work with.
Do the Hoverfly guys have anything up their sleeves?
Wish list:
Smaller FC w/Pro board features
Professional Form Fitted Casing
PPM or SBUS Rx connectivity
Macintosh Software
Okay... blast away! :nevreness:
Wish list:
Macintosh Software
