Failsafe
jetkrazee
Uplifting-photography.com
Was wondering if I were to program my 14SG to have a dedicated failsafe (failsafe is "TX off" at present) or RTH switch it would be possible to change back to manuel mode, gps
or attitude during flight. Just trying to figure all this out lol :tennis:.
Thanks in advance, jetkrazee
jetkrazee
Hi Pete, again please forgive me as this is all new and the equipment I'm inquiring about belongs to a good friend, just trying to help him out. The TX is a Futaba T14SG and the MR is a turboace matrix with naza m V2. It is supposed to have telemetry installed as well.
cdrking
I am new to MR and just setting up a TBS Discovery with a Futaba 8FG. I am using a Naza M Lite for the MC. What I did is setup the right front three position switch with three settings, all the way forward is Manual Mode, middle position is ATT Mode, all the way up is fail safe. I do not have GPS on mine at the moment so this may be a bit different than your setup.
Is this the proper way to set this up?
Thanks,
Jeff
If you want to program one button to activate fail-safe you need to mix two switches. First you need to program one of the 3 way switch to change gps att and manual mode.
Then go to mixes and set the value change when the x switch is activated. The main channel and slave will be the same used for the U channel.
