I have an mk hexa with Wookong m and a MX20 transmitter.
I want to make sure failsafe is set up properly so that it will work when the MX20 is switched off.
The assistant software shows that when the MX20 is switched off it goes in to failsafe on the slider display.
The question is do I needs to set the throttle for failsafe? Do you have to set the throttle to above 10% in failsafe mode and if so how do you do this.
Can anyone run through setting up failsafe for me?
