F550 Hover
Chalagi
This morning I spooled up the 550 into a hover. Which was not very stable (As in staying in one place). I twas moving about some as to where I had to always give it some input. Wind this morning was pretty calm also. These are my settings.
Pitch------140
Roll-------140
Yaw------120
Vertical---140
Attit:
100 & 100
Any suggestions?
Increase or decrease the gain? Its also has a small bobble to front and back. Was using a 3S 2200 mah battery, DX7
VINHEX
Not sure if you have, but if you've done an update did you set everything to default and the setup again.
Also try a calibration on the gps..
Chalagi
I did an update on software and firmware also and then did a recalibration and set my gains to what they were before. Sorry no gps right now just the naza. I have redone the gains since then and they are:
Pitch 160
Roll 160
Yaw 140
Vertical 160
Attit" 90 & 80
Waitig for the wind to die down some
fvg007
I have F550 stock package. I have problem of holding fix height by itself.
Setting: intelligent cut off , Lipo protection: On, Gimbal : On
http://www.youtube.com/watch?v=btRTuj_7l4Q
Then somehow, I reset everything - include assistant reinstall and I turn Lipo protection - OFF, Gimbal - OFF.
After calibration - it works perfectly ( One thing I notice right away - motors will stop within 3 sec if no power add after CSC)
Today - I turn on Gimbal and Lipro protection, System not working right again! ( I notice - motors wil NOT stop within 3sec if no power add after CSC )
I do know all setting are correct, calibration on both control and compass.
Any ideas ?
