are you sure that the connections at both ends - AR8000 and Naza - are the right way up?
Have quadruple-checked this... They are connected right...
make sure where it says receiver type at the top of the screen you calibrate at is set to traditional and not d-bus
You have to calibrate a couple times to get the error to leave once you get it going
It's set to traditional--did this right away... When I click the Start, the slides do not correspond with the stick movements... Here are more details about the setup before I proceed:
The ESC's are DYS 30A ESC. So they have internal BEC. I was told by the original builder (bought this as a "brand new" build that was supposed to be RTF--but came with no RX and you know the rest) that the red wires going from the ESC to NAZA need not be cut unlike what I've read in many other places... He's a great builder and very knowledgeable, so I left the power cables there...
The VU is not connected except for when USB is needed. I understand the benefits of the LED when flying, but I haven't soldered it to the MPB yet. So what I asked him originally was whether I could power the VU through a spare channel on the RX. He said yes originally. But I guess I caught him at a bad time, since later he said he was wrong and that shouldn't have been done... nothing smoked, etc. when I did connect it that way though. May I have bricked the NAZA that way?!
I am using a brand new AR8000 + satellite. Both of them bind with the brand new DX8 just fine. The lights in RX/sat flash like they should
when binding. BUT when the system is powered up, the RX or sat show no sign of any lights inside them. This is my first "air" RX unit, but all my ground units do have a light that lights up and stays lit while powered... So could I be dealing with a faulty RX unit perhaps? But then again, they bind find it seems... Update (as I was typing this!): I found another RX unit (an AR6110e) and bound it with my DX8 (again with no problem). But the same exact symptoms! I plug the VU to the NAZA's LED pins only (not powered through anything else), then connect the power to the system, then I hook it to my PC via USB (have done it in different orders with identical outcome). The LED turns solid green. And I immediately get same symptoms as before--this is the same whether I am using the AR8000 or AR6110e. Basically same thing Bowley used to get:
http://www.multirotorforums.com/vbulletin/attachment.php?attachmentid=3202&d=1325692026. I reversed the throttle... changed my two-position switch to see if it'll kick out of the fail-safe, etc. with no luck. When I click on Start for calibration of the TX, the slides do not move when I move the sticks on the TX--no matter what RX I am using...
And when I turn on the unit without USB attached but with the LED connected and powered through a separate battery (not RX anymore), the LED will go through the initial green flashes (I think 3 or 4) and then pauses and then continually flashes red (not orange). Nothing arms the motors or any other movement. The RX/sat light do not come on either...
The builder/seller thinks that the NAZA has been bricked somehow. He's cool enough that he's sending me a new NAZA; I'm sending this back, but I just don't want the new one to get bricked if that's what happened to this one!
I still think that once I upgraded the F/W things started going to south. I should've not upgraded it to see if that thing was even working or not!
Oh and one last thought/observation: One of the ESC's (number 4) tends to get really warm (not hot to the touch, but definitely warm) when the whole thing is powered up (whether when I am connecting to USB or without the USB just powered up and hopelessly waiting for something miraculous to happen!), while the other ESC's are cold and lifeless...
