ZAxis
Hey everyone.
Ok so the Y6 has been out and about for a number of flights and performance and power wise it is great however as most MR's it has its little niggles. just wondering if I threw some of them out there then i can solve/improve them.
Firstly it does have a tendency to drift in neutral hover position, it is easily controllable but does not hover as good as i think it can. Is it just a case of trimming on the Tx or are their other things I can do to stabilise the craft better? Motors are all aligned, props balanced and the craft is calibrated using an onboard bubble level.
secondly theI have noticed the gimbal (Av130, Sony NEx5) does loose the horizon quite regularly and can become really confused causing it to shift right over onto one side. a short sharp bump with the controls usually sends it back but the gimbal is brand new and doesn't stick in a mechanical sense more an electronic.
coupled with the last point is that the craft also can become confused causing it to stay stuck on an angle until i manually correct it. It doesn't happen all the time but i have noticed it happen on more than a few occasions. usually during higher speed manoeuvres or a long straight flight say 100meters or so. Video from the gimble dosn't suffer from any jello but has an annoying wobble, maybe i'm being picky but after seeing alot of videos which haven't been stabilised I'm not sure mine is up to the same standard.
I will get some screen shots of my MK tools to see if anybody has any settings tweaks that may help this but using the MK help function I'm going to be honest I'm pretty baffled at the different number of options. OK I think I've asked enough already.
thanks in advance.
Lec.
thanks in advance.
