Zaidy
Good day to you all.
I have a bit of a problem with my DJI Wookong and was wondering if anyone else had experienced the same issue
While connected to a PC and the Motor output indicator clearly stating motor output is OFF, I was calibrating my TX and the motors all 8 of them started (when both sticks are in the lower extreme corners out) and I can shut them down (if I position the sticks in the lower extreme corners in) , thankfully the props were off !! so no injury or damage there !
This only occurs on my Octo and NOT on the the S800evo which has a DJI Wookong as well!!! :dread:
Any help advice or suggestions are gratefully received.
Thank you
Zaidy
Thank you
Zaidy
