DJI Wookong-M glitch with firmware update 5.06.
edg428
Hi I was wondering if anyone else is having problems with the new firmware upgrade? I have the Gaui 500X and it flew great, connected it to my computer to set the voltage for 4S and was prompted to upgrade the firmware to 5.06. Now that i have done this and went through re-setting all the parameters the quad goes up a few feet then starts to wildly oscillate out of control and crashes. Everything is set to default and not sure what to do to it. I have snapped a few blades already and almost cracked the frame from the first time as it was up around 10 feet when it did it. Any thoughts or suggestions would be much appreciated!
Thanks,
Ed
DucktileMedia
It sounds like there are some issues that vary form heli to heli. my biggest issue is with yaw. But in general i think they made the gains go higher to give more precision in the same over all range. For most the default gain of 100 is way too low. Set it to a slider or knob on your radio and tweak it on the fly, it's the only way.
