DJI V5.14a with S800/WKM
DennyR
Has anyone had any problems with this Beta firmware on any S800 running with the latest/modified ESC's?
So far I have had none, even running in high 35-40 deg. temps. but it's always good to know if others have. Some, I know did have an issue with the earlier ESC's.
I have had some issues with wind making mine give a attitude bad reading then it drops a little and I have to pull out with almost full throttle to steady out then it is fine. Not sure if this was a problem on 5.12a as I came from just 5.12 and I was told I need to fly in less wind that it may be causing problems messing with the barometer. Not sure dji advertised stable flight up to 17mph and I sure was not flying in that much wind. What happens is while flying a gust comes and led starts flashing three white then purple three white then purple after it stabilizes it is fine but if I was to close to the ground it could come down .....
Sent from my SPH-D710 using Tapatalk 2
