DJI on X8
rsun
Anybody tried out a X8 setup on a WKM....
And how about a octo, is it still a no go on that or will it be a fine controller for that....
Planing on playing around with my Cinestar to get it flying better in wind....
It just keep on being bad wither with a lot of wind in Denmark, so have to try something out... lol
Thanks for looking..
For lots of wind X8 seems to perform better. Wkm and wind do not go well together unless you have Zenmuse.
Eh.. have you not seen any of my videos in the wind with my ADX3.. WKM are fine in the wind.. it just depends on what you are expecting of it. Camera on a pole no but flying dynamically there great.
hugy
This is my x8 with wookong flying around.
I also use it with my zenmuse
jffry7
aka TruckBasher
I had been using wookong on my retired x650 v8 and now ADX8. I like how X8 fly. Both have pros and cons but it boils down to user preference. It has been argue every now and then just a matter of preference (and of course the over all setup)
rsun
Thanks guys for your answers...
One more question, Do you use the same size props all around or du you use a higher pitch on the 4 low props... ??
jffry7
aka TruckBasher
I use same props, find it better well the gain in efficiency of the coaxial motors is not that better as with the way my multi flies. But I havent tried different pitch (tho there is very limited options you can go with pretty close weight)
Lanzar
On dji if you want to have different props you need to do manual mixer for motors.
rsun
Hey Lanzar
It is from you I got my inspiration from and will get a hold on Matjaz for some parts and more info on your setup.
Also going to try out your KW4 and KW8 on the X8...
Thanks again.
Lanzar
HAHAHA i am glad we insipe others. Well we have a lot off aces in our sleave. Stay tuned :)
Hey Lanzar
Thanks again.
Fredasss
Hello Lanzar,
I looking to try different prop sizes in top and bottom of my X8, but don't know how to make the table mix to get same as Mikrokopter X8, can you help me in this ???
thanks
Lanzar
Hello Lanzar,
thanks
as soon as i am in office i will try to give you link. i do not advise on different pitch since there is just too much work. unless you w
have like 600 eur extra to experiment with props.
I have an XAircraft X650, an X configuration that has both Graupner 'pullers' and 'pushers' on each of the four arms. I use the Wookong FC and have to say that it is an incredible platform for photography. It seems to deal with wind very well and I wouldn't hesitate to recommend this outfit.
