DJI Naza V2 M - Will it work with Xaircraft Gimbal?
I have an Xaircraft x650v heli with Gimbal - I want to install the new NAZA V2 M flight controller to it.. Does anyone know if the gimbal will work with this flight controller??
I can maybe help if you can tell me what Xaircraft inputs it takes. The Naza can control pitch and roll axis servos. The roll is fully controlled by the Naza to keep the gimbal level. The pitch is controlled by the user and the Naza; the user can pick a tilt angle, and the Naza will keep it at that angle even if the aircraft is tilted more or less for accel/decel. Make sense?
Frankie. You said "3 servos", but the link you provided says it's a two axis gimbal with two servos (pitch and roll). These are the same to axis I was talking about above. The "pitch" one being the tilt for pointing the camera up and down. Then the "roll" servo is for keeping the camera level to the horizon. But I do see that third servo in the photo, but it looks like that is the shutter control... hard to tell. There isn't anything that stands out as not being supported by the Naza, but that's me speculating based on what I'm seeing at the link.
Yep sorry my mistake.. Has 2 x wiring sets coming out of it anyway.. Well ok thanks for the info, will buy the Naza and see how it goes...
