Hello guys,
I have a 650 size quad with F-30A (Simon K) ESC's and NX-4006 motors, spinning APC 14x4.7 props, and it flies pretty well. it is equipped with Naza V1 on V2.02 (used to be V3.14 but i downgraded as a precaution from fly aways).
lately i changed to Graupner 14x8 props (much more balanced) and the quad flies even better but noticed on the first day of flying with the new props that when i was flying forward (S->N) with the sun in the W direction, the quad would all of a sudden lose altitude quickly and to stop the fall i had to release forward stick, and it would stop and climb again, but once flying forward again - the same happend.
so i thought this could be the sun sensitive barometer, i landed and put black tape ONLY on the left side of the naza (this side was facing the sun when it happend. this seemed strange as it never happend before with the APC props (could be coincidence). anyway continued to fly that day with no problems up to 2Km away and back (FPV).
flew again yesterday, and again flying S->N with the sun at W caused the same thing (tape is still on the Naza!) so i turned 180 degrees (nose facing S while sun is in W) and flew backwards (i.e S->N with sun in the W but nose pointins S) and it still happens.
it only happend in that flight yesterday. next flight it was fine.
i can confirm 100% there is no voltage drop in the battery as i can see the OSD battery voltage stable and high enough (4S Lipo 10,000mAh 20C flies for 20 minutes).
please express your thoughts.
thanks.
thanks.
