Dji Naza + Turnigy 9x (original firmware) help please !!!
cman319
3way switch not needed, just use the thro hold for the 2 naza modes. set the endpoints so that you are in the middle of the areas for atti or manual mode. you can see this while you have your naza connected to the pc.
I never warmup my 9x and never had any problems.
lcbdl
Hi,
I met the same problem. I bind gear with aux1(ch5), tried to set end point of ch5. There are two values for each channel, aux 100% 100%. I can only move cursor to the first value and change it, but can't modify the second one. when I change the value, the Control mode scroll bar doesn't move at all. Can you help me? I really appreciate it.
Chuan
lcbdl
Thanks a lot. I finally made it work. I chose a wrong channel - ch5, ch5 is used by gyro. When I changed to ch7, everything is very clear. Thanks again.
