DJI NAZA LIte Compass fails to calibrate.
R Shaw
JR 10X with dm9 2,4 module. plush 30 amp esc's. Red wire still hooked up. radio set to ppm(cleaner signal). I did the radio calibration and set it up to manual-atti-gps on aux 2. its a 3 position switch. flip switch 11 times and it will start. spin one time with the hex flat. goes green. tilt it 90 to the right and spin it 360 and it goes flashing red. It will do the same thing if I try to start it up normal. Green led will come on flashing 3 times and go to flashing red fast. Any one run into this?
cootertwo
So you did one turn with it flat, till the light changes, then point it down and do another turn until the light goes solid, right? Usually on the second turn, I have to go just a tad past 360 degrees before the light goes solid. Or it could be the gyros out of calibration.???
AndyPG
Hey R,
Did you get sorted?
Does sound like this is your issue for the failed calibration.
Like cootertwo said, nose should point down for the second phase of calibration.
Andy.
