DJI Lightbridge new firmware
Hi, Dear DJI Lightbridge users,
Considering the needs of 1 pilot solution, DJI will release a new firmware for Light Bridge (LB) this week.
With this firmware, when Tx A 8CH (via Red plug) and Tx B 8CH (via Black plug) are connected to LB ground system, the Dbus port of LB air system will output total 16CH, while Gimbal port will output 8CH of Tx B for Zenmuse HD gimbal.
When only 1 Tx A with less than 16CH is connected via Red plug, all channels will be detected and sent to LB air system, which will output all channels via Dbus port. In this case, Gimbal port will not send any channel signal to Zenmuse HD gimbal.
Please click here for more information.
rcflyerheli
You know if DJI had just released this d#^m thing like the advertised they would, or would get the additional power cables to the dealers like they now say you have to have to power it up, or if they would have just said that if you aren't flying a Vision don't get it, I wouldn't be nearly as fed up with them as I am.
All they had to do is one out of three, and they haven't done any of them.:livid:
Flubbs
sent mine back so disillusioned that it wouldnt work as advertised with a two man set up on an s800
