DJI Ground Station and red led on BTU
Flydigital
Recently acquired a DJI GS package which worked just enough to have a play with the settings (didn't get to the field). It kept disconnecting and now won;t connect at all. Red LED on the BTU component. (BTU works fine plugged directly into the NAZA.
There is talk elsewhere of a firmware update needed here: http://www.rcgroups.com/forums/showthread.php?t=2059447&page=2
Does anyone have a problem with the GS? I'll hold onto it if it can be sorted, otherwise I'll send it back.
Quinton
Hi did you get this fixed ?
Im having problems connecting my GS
I set mine up yesterday and had the exact same problems, so I took the CanBus cable that was coming from the iosd and tried it in the spare GPS one, and it started working perfectly.
Hi Quinton,
Did you get it working with the IOSD plugged in ?
I will have a go with mine today
Cheers
