genesc
I may be all wet on this idea but I was thinking.
It seems vibration on electronics with quad copters is an issue. I have looked at all kinds of exotic materials online for dampening vibration such as Zeal tape etc. Most is very expensive for what you get.
I was thinking about buying a tube of silicone and squeezing a fair amount out on a piece of wax paper, then laying another piece of wax paper
On top of the silicone that I squeezed out. Putting this on a flat surface and laying a flat piece of steel on top of the top layer of wax paper.
Then compressing it all under pressure where you end up with a thin layer which would probably look like a thin pancake when dried. Then cut
Squares to fit under electronic components. I would think some thin two way tape stuck to the piece you cut out would bond your receiver or
Control boards to the plate. Silicone would act as a dampener.
Has anyone tried this? What are your thoughts and if you have anything to add to this, it would be great.
Accepting any constructive criticism as well...
Gene
Gene
