sophia lee
Hello, everyone. I am sharing how to connect Benewake TF LiDAR to Arduino.
May this helpful.
Step 1: Hardware Connection
The linear order for the LiDAR products of our company is defined as: red +5V, black GND, green
TX, white RX; the power supply voltage for TF02 is 5V, so it is permissible to directly connect 5V and GND on the Arduino board. For other LiDARs, please refer to product specification to ensure normal power supply; For serial communication connection, please note that with regard to Arduino UNO board, the TX end of LiDAR connects to pin 2 port (soft serial port Serial1’s RX) and the RX end of LiDAR connects to pin 3 (soft serial port Serial1’s TX). This is relevant to the programming hereinafter; For Arduino DUE board, the TX end of LiDAR connects to RX1 port and the RX end of LiDAR connects to TX1 port.
Step 2: Programming
The implementation of this routine functions requires at least two serial ports: one for receiving
data from LiDAR and the other for sending data to PC for display. You can copy the following code to
IDE syntax editor or directly open corresponding attachment files.
/* This program is a parsing routine of TF02 product standard output protocol on Arduino.
The format of data package is 0x59 0x59 Dist_L Dist_H Strength_L Strength_H Sequence_L Sequence_H CheckSum_L
Refer to the product specification for detailed description.
For Arduino board with one serial port, use software to virtualize serial port’s functions: such as UNO board.
[HASHTAG]#include[/HASHTAG]<SoftwareSerial.h>// soft serial port header file
SoftwareSerial Serial1(2,3); // define the soft serial port as Serial1, pin2 as RX, and pin3 as TX
/*For Arduino board with multiple serial ports such as DUE board, comment out the above two codes, and directly use Serial1 port*/
int dist;// LiDAR actually measured distance value
int strength;// LiDAR signal strength
int check;// check numerical value storage
int i;
int uart[9];// store data measured by LiDAR
const int HEADER=0x59;// data package frame header
void setup()
Serial.begin(9600);//set the Baud rate of Arduino and computer serial port
Serial1.begin(115200);//set the Baud rate of LiDAR and Arduino serial port
void loop()
if (Serial1.available())//check whether the serial port has data input
if(Serial1.read()==HEADER)// determine data package frame header 0x59
uart[0]=HEADER;
if(Serial1.read()==HEADER)//determine data package frame header 0x59
uart[1]=HEADER;
for(i=2;i<9;i++)// store data to array
uart=Serial1.read();
check=uart[0]+uart[1]+uart[2]+uart[3]+uart[4]+uart[5]+uart[6]+uart[7];
if(uart[8]==(check&0xff))// check the received data as per protocols
dist=uart[2]+uart[3]*256;// calculate distance value
strength=uart[4]+uart[5]*256;// calculate signal strength value
Serial.print("dist = ");
Serial.print(dist);// output LiDAR tests distance value
Serial.print('\t');
Serial.print("strength = ");
Serial.print(strength);// output signal strength value
Serial.print('\n');
Step 3: Data View
Upload the program to the Arduino board and open the serial monitor to check the distance value
detected by LiDAR in real time and corresponding signal strength as in Figure 3;
Besides, you can also check the data curves on the serial curve plotter, but for that you need to
modify the code related to serial printing (Serial.print):
// Serial.print("dist = ");
Serial.print(' ');
// Serial.print("strength = ");
Serial.print('\n');
Re-compile and upload them to Arduino board. Open the serial curve plotter and you can see two
curves representing distance and strength as in Figure 4.
May this helpful.
Step 2: Programming
int i;
void setup()
void loop()
uart[0]=HEADER;
uart[1]=HEADER;
Serial.print('\t');
Serial.print('\n');
Step 3: Data View
Serial.print(' ');
Serial.print('\n');
