ManticoreH
For sale: Full Cinestar 8 package w/ robust set of spares & tools!
Upgraded to 5S flight packs, comes w/ 9 of them (only been used on one shoot day). 3-Axis Cinestar gimbal w/ FreeFly Radians. Comes w/ nearly enough spare parts to build a 2nd Cinestar (including a spare FC & BL)! Also comes w/ a large road case which allows it to ship fully-assembled. All motor bearings recently replaced. Many upgrades, read on.
The full list is extensive, please read fully and browse pictures if interested...
Cinestar 8 Core Package:
Spare Parts:
Included Accessories & Tools:
The road case and backpack have wear and tear, but the package is in great shape! Only seen about 40 shoot days total, very few full-throttle maneuvers (most clients like slow & steady). Gets mind-blowing shots with serious cameras!
Copter is in Los Angeles, CA.
We've spent at least $25K on this package with upgrades & spares, this is one of the most complete kits out there... Asking price has just been reduced to $8,000. Will consider all serious offers!
View attachment 19064View attachment 19065View attachment 19062
View attachment 19063View attachment 19060View attachment 19061
- FreeFly Cinestar 8
- MikroKopter flight control 2.1 (upgraded to 5S)
- MikroKopter BL
- (8) Quadrocopter QC3328 motors
- (8) APC 14x4.7 composite propellers
- FreeFly 3-axis gimbal
- (3) FreeFly Radians
- Upgraded 8-point vibration plate
- Upgraded (stiffer) vibration dampener rings
- Dual adjustable tilt bar
- Upgraded metal shaft & tube clamps (in key areas)
- V2 landing gear with extensions
- Manfrotto quick release & plate
- 900 MHz FPV system w/ camera (pilot)
- 4” TFT LCD monitor (for pilot FPV)
- 1.2 GHz wireless video (gimbal)
- Flat patch 1.2 GHz FPV receiver antenna
- Spektrum DX8 transmitter w/ upgraded thumb sticks (pilot)
- Spektrum TM-1000 telemetry unit
- Spektrum DX6i transmitter w/ upgraded thumb sticks (gimbal)
- (9) Turnigy Nano-Tech 8000mah 5S LiPo batteries (flight pack)
- (2) Turnigy Nano-Tech 2200mah 3S LiPo batteries (gimbal)
- (2) Quadrocopter 1200mah 3S LiPo batteries (pilot FPV)
- Hyperion EOS 0720i Duo 3
- PRC500 Power Supply
- Hyperion EOS 0606i
Spare Parts:
- Spare MikroKopter flight control 2.1
- Spare MikroKopter BL
- Spare Spektrum TM-1000 telemetry unit
- (2) Spare Quadrocopter QC3328 motors
- Freefly F360-0866 servo
- Freefly Potentiometer
- 8-Point vibration plate
- Original 4-point vibration plate
- Vibration dampener rings (full looser set for lighter cameras)
- (5) APC 14x4.7 SF composite propellers
- (5) APC 14x4.7 SFP composite propellers
- (3) 450mm booms
- 400mm boom
- (2) 100mm booms
- (2) 125mm booms
- 215mm boom
- V2 landing gear
- (12) Motor bearings
- GPS mounting assembly
- (2) Gimbal replacement belt
- Gimbal lightweight roll/tilt pulley
- Camera mounting plate
- (4) Boom end caps
- (2) Small servo pulley
- Tilt bracket
- Roll mount assembly
- (2) Dual bearing tilt mount
- Top boom connector
- Upgraded top boom connector
- Vibration dampening bracket
- (3) Boom connector
- (3) Servo mounts
- (15 pairs) Frame clamps
- (8 pairs) Metal frame clamps
- (2) Shaft clamps
- (2) Gimbal top frame plate
- Cinestar tripod screw
- Spare hardware (screws, nuts, bolts, etc. all sizes needed)
- Spare electronics (wires, cables, connectors, etc.)
- Color decal sheets: red, yellow, and blue
- Large custom road case (45” x 45” x 22”) by Encore Cases
- Tamrac Expedition 8X backpack
- (2) Marmot hip bags for FPV receivers (stay mobile!)
- 40 watt soldering iron
- Solder station w/ magnifier & LED light
- Voltage meter
- IR thermometer
- (2) Lead solder
- Rosin flux pen
- De-soldering copper wick
- Heat gun
- Assorted heat shrink kit
- T-handle ratchet driver
- 2 & 2.5 mm hex drivers (multiple)
- Bearing installation tool
- Small handsaw
- Wire cutters
- Wire stripper
- Needle nose pliers
- Forceps
- Duffel bag
