SleepyC
www.AirHeadMedia.com
Everything in One Box
Flight-Ready Chroma Drone with Stabilized CGO3 4K Camera • ST-10+ Controller with Touch-Screen Display
• Long-Lasting 5400mAh LiPo Flight Battery • Flight Battery Charger • USB Programmer Cable
Everything at Your Fingertips.
You don’t need a separate smart device with the ST-10+ controller. Everything you need, including the camera controls and a touch-screen video display, is built right in.
SAFE Plus technology gives you several flight modes that have been specially programmed to make smooth, steady image capture easy. In fact, it can make you look like a pro even if you’ve never flown a camera drone before! All flight modes feature self-leveling and use GPS and altitude sensors to precisely hold position. SAFE Plus technology will even land the aircraft for you if you activate the Return Home function.
This version of the Chroma drone gives you the added benefit of Follow Me and Watch Me flight modes that let you focus on getting the shot while the drone does the flying.
- Large, 5 ½ inch touch-screen display with intuitive Android interface
- Displays live video and real-time telemetry info like speed, altitude and battery voltage
- Clearly marked switches and buttons
- Super-simple flight and camera controls
- Slider switch for adjusting camera tilt
- Slider switch for adjusting drone speed
- Smart Mode
Perfect for first-time drone flyers.- Stick Relativity moves drone in whatever direction the control stick is pushed, no matter which way the nose is pointed
- Creates a SAFE Circle™ barrier that prevents the aircraft from flying too close to you
- Auto-holds position and altitude when control sticks are released
- AP Mode
For more experienced drone pilots.- Responds like a conventional drone without Stick Relativity
- Gives you greater control authority by turning off the SAFE Circle
- Keeps control response smooth so panning and tracking shots look great
- Follow Me Mode
Your built-in copilot.- Frees you to focus on lining up the perfect shot
- Pan and tilt the camera while the drone follows
- Drone follows at an altitude and distance you set
- Tracking Mode
Be the Star.- Drone follows and keeps the camera pointed at whoever holds the ST-10+ controller
- Resume full control at any time
- Return Home
Safe landings with the flip of a switch.- Returns the drone to its start-up point and lands it for you
- Great for first-time flyers who aren’t ready to land themselves
- Easy way to regain visual contact if you lose sight in flight
- Activates automatically if controller signal is lost
- Adjustable Flight Boundaries
Stay legal. Stay safe. Fly responsibly.
- Keeps the drone within altitude and distance limits you define
- Easily adjusted using the Chroma programmer
- Helps you avoid sensitive airspace ...and neighbors
