Build Issue with Radio
inmanster
Build Components:
AfroFlight Naze 32 Rev5
FrSky D4R-II Receiver
FrSky DJT Transmitter
Turnigy 9XR Radio
Floureon 3S 2200mAH 25C Lipo Battery
MultiStar 2206 V2 Motors
Afro 12A V3 ESCs
ZMR250 3K Carbon Fiber Frame
Gemfan 5X4 Props (still in the unopened pack)
No cameras or telemetry at this time just a simple small build.
I soldered ESCs to PDB and connected it to the Naze. Motors are connected to the ESCs and Naze in the standard X formation and the Naze is connected to the D4R-II with one servo cable. I have a jumper between 3 and 4 on the D4R-II. This image is exactly how I'm set up to this point. I bound the Rx and Tx. I power up the radio and then connect a battery to the PDB of the quad and everything looks like it powers up correctly.
I can connect to Baseflight without issue. I enabled PPM and a few other things that are recommended (don't remember off the top of my head what they are). I synced my motors and can spin them up from within Baseflight. I have the radio setup to match the channels of the Naze (Ch1 A, Ch2 E, Ch3 T, and Ch4 R).
Now here is my problem when I go to the Receiver tab in Baseflight everything is at 1500 and there is no movement from my sticks. I have a FrSky 8R-II Plus Transmitter too and I get the same lack response with it. This is my first time using the Naze 32 and am at a lose of how to proceed.
Any suggestions?
Hoki
did you set your transmitter to be in ppm mode? I'd use cleanflight. baseflight acts wonky from my experience.
