Battery for f450
Is a bit small but should at least run for 6minutes or so. What voltage was it when you started/finished? Also in the naza assistant you can set the voltage warning level. I always lowered mine to 10.2V
Sent from my C6903 using Tapatalk
Prehn
Can it lift such a huge pack?
Does the phantom 1 not come With 2200mha?
I just thourght something was wrong as i Get 30 sec flight
Prehn
Wow. Thats impressive. Iv got 4's 5000 batterys for my buggy, and they are heavy.
But now i tryed to lower cutoff to max. It Will not go lover than 9,9.
When i recharged my packs before they where at 4,0v pr cell.
Will se tomorrow what it does.
Prehn
Yes. When i start out they are 4.2. And when it flash red they are at 4.0.
But yesterday it was raining, so i did not test the new cutoff setting.
chipwich
Can you post a screenshot of your battery config page in DJI Assistant? Sounds like you are configured for a 4S pack, instead of the 3S you are flying.
Prehn
Finally succes.
Today i got three packs in to it with over 5 min of flying.
The lipo cutoff is now set to 9,9v for my 3s batteries. It is as low as it gets for the software. I Think it is Strange, as i normaly set cutoff to 3,2 Per cell. Sometimes lower in my racecars.
But it worked and im happy.
Thanks for the help in this thread.
