I added FPV and a Camera Gimble to my quad. Now when I have it do a return to home and auto landing it decends too quickly and lands fairly hard. What adjustments do you think I should try to slow it down.
Rich
Are your Mounting and COG settings all accurate?
Ok let me get this into my head as I'm new to all this, I know about the GPS X,Y,Z settings, and the IMU which I have smack dead centre so X and Y will both be set at 0 cm. So it comes to the Z setting, from where do i take the measurment from the frame? is it half between the base plates, and is it half of the IMU?
HA! get DJI to help? thats a good one. thats like asking Holger if he wants to do Lunch or asking Jeff from Xaircraft to call you back or getting a paid return from HobbyKing or expecting these things to fly out of the box.
Joking aside, it would be great to see a true way to determine this. Robert from DJI USA told me how but it really didn't make sense to me when I tried it out.
There is no set position, it depends where the center of gravity on that axis is and that will depend on what you have above and below the center plates. Usually a gimbal with a DSLR on it is going to lower the CoG for the Z axis significantly, if you have a setup like on the CineStar frame with the battery weight up above the electronics on the top plate then it tends to offset some of the weight of anything below the centerplates.
The trick is finding a way to accurately determine where the CoG is on the Z axis for any given frame, one way to do that is hang the multi by the end of an arm with it fully RTF, battery(s) included and see where a vertical line dropped from the point the frame is suspended from crosses the frame itself, that should be the CoG for the Z axis. You may want to hang it from a couple of arms and see where the vertical lines intersect to get a better idea of where the point is.
Once you know the CoG then the measurement is supposed to be to the center of the IMU, so there's going to be some amount of estimation involved as I haven't yet found a way to do it very accurately, +/- 1 CM is what DJI says it should be.
What I do is put the frame on the floor so its straight up and down (Perpendicular). Mark that spot.
Lift frame off the floor, let it sway and come to a stop. Set on floor, Mark that spot. Measure the difference of the two spots.
That is the Z Axis.
Seems to work for me.
That is exactly how I did my Z axis. On my first set up I balanced it on the edge of a steel rule.Z axis is easy. Load up and hold your multi up as it would fly. Now turn it through 90° so that the booms are pointing up and down, left and right. Top is against your chest and landing gear away from you. Now try and balance it on your hands by holding it, say, under the booms. If it tries to tilt away from you, move your hands further away, so maybe under the lower plate. (all the while on its side) If it tilts towards you, balance it on a point closer to you, so that when you balance it, it could go in any direction as easily as the other. You won't get it 100% accurate, but pretty damn close.
I'll make a quick video to try and explain this further tomorrow!
Gunter.
