Hello guys,
I'm using Graupner HoTT MX-20 for copter control. And recently bought a MX-16 to control gimbal. I was using Spektrum DX8 but it's dead now. While reading regular topics, I came across a problem which states "When two Graupner Hott receivers used on the same craft, it can interfere with each other and have some range problem".
Here are the topics mentioning this problem:
http://forum.freeflysystems.com/ind...nd-operator-futaba-8fg-or-graupner-mx-12.203/
http://forum.mikrokopter.de/topic-35500-2.html
What Holger says about this:
What Graupner says about this:
Are there anyone using two HoTT receivers on the same copter without issues?
yes, then the telemetry be disturbed. This is because the telemetry channels of both receivers are not successive synchroinisieren and then has to data collisions because both transmit simultaneously. You should either:
- minimum clearance of 1-3m between recipients meet
- bind two receivers on the same transmitter
If your model is fitted with two or more receivers, it is absolutely essential that you do not carry out programming work e.g. with the Smart-Box during a flight, as this alter the settings in all connected receivers and this can lead to incorrect settings; in the worst case this could result in the model crashing! For this reason always carry out programming on the ground, and make sure that only the programmable receiver is powered on.
