AKASO F250S RTF Racer Quadcopter QAV 250 Carbon Fiber Frame with Remote Control Review
akaso
The popularity of drones is increasing by the day, same to competition between manufacturers of drones. If you are look for a drone, then you need to go for the best one in the market, and one that suits your needs. Compare the features and prices to arrive at a better choice. Below is one of the best drone, so read more to find out why.
Product Description
AKASO F250S is an Unmanned Aerial Vehicle (UAV) controlled by a remote control. This quadcopter has good distance coverage when airborne and it is the perfect drone for an amateur starting out on drones. It comes with a price suitable for your pockets hence you won’t have to break your bank. AKASO F250S racing drone is easy to operate and more like DIY equipment. It comes with some great features that are bound to make you stick with this drone and enjoy working with it.
This quadcopter comes already assembled from the factory and you only have to charge its battery to full capacity before starting with your flights. It comes with a presence control channel with a remote that lets you monitor its movement with its strong signal over a wide distance.
The drone has onboard LED lights that make it appear so adorable and easy to identify. The lights also help the drone’s camera to take clear photos whether during the day or night or in any weather condition; rainy or not.
It has four blades that propel it at each corner with all its other components at the center of its structure.
Features and Specifications
AKASO F250S has some amazing features that make it such a bargain at the price it comes with Compact carbon fiber main frame
Its frame is made of carbon fiber which is strong enough to avoid damage to the drone when it crashes during flight. The carbon fiber is made up of more than two material types that have distinct properties to make it a better material for reinforcing the casing. The components making up the carbon fiber is lightweight hence does not cause any drag to the quadcopter.
LiPoly Battery and Charger
This LiPoly battery last for longer periods and may even make the drone surpass its minimum flight time as stated by the manufacturer. There are no breaks in flight due to the strong battery it comes with, so long as it is fully charged before takeoff. LiPoly battery reduces the frequencies of taking the drone down so as to charge the batteries, and also time taken to charge the battery reduces significantly; the batteries charge quickly. They have light weight hence a plus to the drone in flight mode. The charge amount of 3S 1800mHA 25C 3S LiPoly provides this AKASO F250S with enough energy in small amounts.
This battery allows the quadcopter to achieve a flight distance of 200-500M.
2300KV motors with matched ESC’s
AKASO F250S racing drone comes with 2300KV motors with matched ESC’s puts the drone top in its class. Quality ESC’s matched to the motors are the speed controllers and helps the drone achieve maximum current that makes the drone flights enjoyable. The ESC attached to the motor is brushless, and due to its light weight, the AKASO F250S is able to maintain a constant speed capacity making the flight always enjoyable.
Other features
It is equipped with LED lights to make it easily identifiable and take clear photos. It comes with remote control; 6 channel HT6+HT6DR.
Specifications
Manufacturer: AKASO
Frame Diameter: 250mm
Flight Controller: CC3D with SBUS
Brushless Motor: 2300KV 1-3S Voltage
Brushless ESC: BLHeli 12A
Battery: 3S 1800mHA 25C 3S LiPoly
Flight Time: 10~14mins
Item Weight: 4.41 pounds
Item Size: 8.86 x 11.02 x 11.02 inches
Package Weight: 4.41 pounds
Package Size: 11.02 x 8.86 x 8.86 inches
On purchase of the quadcopter, it comes with:
1 RTF AKASO F250S Quadcopter, 1 Remote Control, 1 1800mHA LiPoly Battery and charger, 8 Blades, 1 Bag and 1 User Manual.
How It Works
AKASO F250S comes already assembled from the manufacture, just charge the battery to full capacity and you are good to go. It has a control channel (6 Channel HT6+HT6DR), with a remote control that makes it easy to monitor the drone inflight, boosted by its strong signal strength.
Charge the LiPoly Battery to full status for a seamless flight session that may last up to 14 minutes. Using controls on the remote control channel start the propeller blades on the quadcopter which is powered by the motors, the quadcopter will start to rise.
Control the speed of the drone by varying the attached ESC as it controls the speed stability. Change direction of the drone by the controls on the remote control to the location you desire. You can take aerial photographs of the locations they fly over also. Recharge the battery when it starts to lose power to make it function better.
Benefits
· AKASO F250S comes already factory-assembled hence it is ready for use after charging its battery.
· The drone has a hard carbon fiber casing that is hard enough to prevent damage to the drone when it crashes.
· The modular design of the drone makes it easy to change damaged components in a few minutes and continue with flights.
· It has LED lights on its structure making it easy to identify its location with ease.
· The lights, speed and flight controllers plug straight into the integrated printed distribution board with no soldering required. This makes it easy to build and repair during races.
· The drone’s camera can take photos in cool or conducive weather.
· Covers a long distance of 200-500M which is way more than most other drones can achieve.
· AKASO F250S can achieve a flight time of 10-14 minutes after recharging.
· Its package from the factory has 8 blades hence enough for replacement when some get damaged.
· The drone comes with a bag to carry it around and protects it from external damage when not in use.
Final Verdict
AKASO F250S RTF Racer Quadcopter QAV 250 Carbon Fiber Frame with Remote Control is the perfect set for beginners starting with drones. Its 2300KV motors with matched ESC's, AKASO F250S flight control mechanism, LiPoly battery and its charger combine to form a powerful drone which has less hassle to make it start flying and protective casing that makes it the best to withstand collisions when starting out with drones.
A decision to get yourself this perfect set of quadcopter is the best decision you will ever make as a beginner.
