6S LIPO pairs available - low cycles and discounted from origianl cost
Status
Not open for further replies.
222GR
Following gtranquillas lead, I too have batteries just lying around unused.
These are from my S800 and set as pairs so I'd like to sell them that way ideally but not necessary. Great shape, low cycles. Take a look at what I have available.
attachment.php
UPS ground $17 or less to ship, USPS Priority 2 Day $12.35 flat rate (this is pairs less than 4lbs or less)US ONLY please.
All gave me 10 minutes + flight time safely. Never over discharged. Never left fully charged. Always monitored. Always stored at 50%
attachment.php
attachment.php
attachment.php
zippy compact 5800 25C
Zippy Compact, the latest addition to our Zippy battery series offers excellent performance and high quality in a "Compact" size. These packs provide the same capacity and discharge rate as our Flightmax line, but give you alternative sizes for applications that require a specific shape.
Great for models with limited battery compartment space!
Zippy batteries deliver full capacity & discharge as well as being the best value batteries in the hobby market today!
Spec.
Capacity: 5800mAh
Voltage: 6S1P / 6 Cell / 22.2V
Discharge: 25C Constant / 35C Burst
Weight: 843g (including wire, plug & case)
Dimensions: 163x46x53mm
Balance Plug: JST-XH
ZIPPY Flightmax 5800mAh 6S1P 30C
Zippy Flightmax batteries deliver full capacity & discharge as well as being the best value batteries in the hobby market today!
Spec.
Capacity: 5800mAh
Voltage: 6S1P / 6 Cell / 22.2v
Discharge: 30C Constant / 40C Burst
Weight: 838g (including wire, plug & case)
Dimensions: 149x49x56mm
ZIPPY Flightmax 5000mAh 6S1P 45C
Spec.
Capacity: 5000mAh
Discharge: 45C Constant / 55C Burst
Weight: 888g (including wire, plug and case)
Dimensions: 144x52x58mm
Balance Plug: JST-XHDischarge Plug
222GR
this was on 12/1 2013
ZIPPY BLUE 5000: B1 - 2.2., 2.0, 1.9, 1.9, 2.0, 1.5 B2 - 2.0,2.0,1.9,2.1,1.8,1.9
ZIPPY COMPACT YELLOW 5800: B1 - 2.9, 2.7, 2.8, 3.0, 1.8, 2.8 B2 - 3.1, 2.9, 2.6, 2.5, 3.0, 2.6
ZIPPY BLUE 5800: B1 - 2.3, 2.5, 2.2, 2.2, 2.0, 1.9 B2 - 2.4, 2.2, 2.3, 2.0, 2.2, 2.3
since then, Compact 5800 had 4 more cycles, Blue 5800 had 7 more cycles, and Blue 5000 had 8 more cycles.
With the Blue 5800's on my charger now all 12 cells show me a range of 2.7 - 2.0 (these packs have the most total cycles of the 3 at 29)
All of the packs have 4 hours or less total flight time on them so yeah, they're still in fine shape.
Status
