Hey Greg,
Going back to your original question here, are you saying that when your Naza 2 is in GPS mode, your quad needs a constant 65% on the stick to maintain hover?
If this is the case, I think there is a minor issue with the TX stick setup.
It sound like you've got a little bit of expotential rate dialled in or an endpoint or midpoint adjustment that needs correcting.
In my humble experience (I'm sure someone will dive in if I'm wrong!), if your TX's throttle stick settings are all default, the Naza should make a steady hover always be 50% on the stick.
What TX are you using?
Are the throttle stick parameters all default?
If you do find any of the stick settings non default, reset them, do the TX calibration again in Naza Assistant and I think you might find steady state hover is 50% stick where it should be.
Andy.
