greg77
HOBBYMATE QUAD charger comes with built-in 110-240v AC power supply. The charger can be also powered from your car battery (DC 11.0V-18.0V input).
It can charge 4 batteries in the same time (up to 120W/channel). Can be charged different type of batteries in the same time.
No USB data link, so you can't monitor the charging process via your PC.
Manufacturer's specs:
- AC Input voltage AC 100V-120V OR 220V-240V
- DC Input voltage DC 11.0V-18.0V
- Charge Current: 0.1A-12.0A each port
- Discharge current: 0.1A-6.0A each port
- Charge power max. 480W, 120W each port
- Discharge power max.40W, 10W each port
- Balance current max. 300mA/cell
- Lithium battery cell count 1-6 (S)eries
- NiCd/NiMH battery cell count 1-15 Cells
- Lithium battery types Li-Po, Li-Hv, Li-ion, Li-Fe
- Pb battery voltage 2V-20V (1-10 cells)
- mAh Capacity: 100mAh ¨C 50,000mAh (Can charge batteries w/ higher capacity, but restarting the charge process will be required once maximum is reached)
- Weight 1600g
- Dimensions 205 x 180 x 70mm
