Advice taken. Letter sent to Chris Anderson via PM. Here is the conversation. This will be my last post on this subject. The conclusion is at the bottom for those who choose not to read it all.
First email to Chris Anderson via PM
Subject: Defective Iris - No support - Please help!
> Date: Wed, 16 Apr 2014 15:58:34 +0000 > From: James > To: Chris Anderson > > Chris Anderson,
> My name is James XXXXXXXX. On March 10, 2014 I purchased the RTF Iris and a few added options. (Order number: XXXXXXXXXX) The total was, $1,633.75.
> The package arrived on April 8, 2014. It only took me 15 minutes or so to realize that there is a major problem. First thing I noticed, the main antenna for the
Iris itself was missing. It was not anywhere in the box. After getting the Iris out of the box and doing an inspection, I noticed that two of the motors were missing
screws. Another screw fell out when I was packing it back up. Out of the eight screws, only two were solid. The rest were missing, stripped, or just loose.
> I have emailed support with pictures. The reply was, we are sending you an antenna and a bag of screws. I don't have the Iris anymore. The screws wouldn't do any
good anyway. The holes were stripped.
> I have already boxed up everything and sent it to the San Diego office. It arrived there Monday at 8:49AM.
> I'm asking for a full refund or a working Iris. I have also given up trying to call the San Diego office. I have tried to call there no less than 30 times with no
luck. My phone number is, XXX-XXX-XXXX. It's on 24/7 and I always answer.
> I'm looking forward to hearing from you and ending this as soon as possible.
> James XXXXXXXX
Chris Anderson's Reply
Chris Anderson
mail@diydrones.com via diydrones.ning.com
Apr 16 (3 days ago)
to me
Chris Anderson has sent you a message on DIY Drones
Sorry to hear about that. It sounds like customer support has been in communications with you via email. Did you ask for a RMA to return/replace? I don't have access
to the customer support threads, so I'm afraid I'm not quite sure I understand what has/hasn't been done at this point. If you just need me to escalate a request I'm
happy to do that.
-Chris
My thoughts on his reply
I'm not a rocket scientist, but I do believe that I mentioned there has been, "no communication with customer support other than them wanting to send me a new antenna and a bag of screws." Also, I wouldn't have written you if I didn't need your help with "ESCALATING" a request to fix the problem.
So, I wrote another letter....
My second letter to Chris Anderson
> Date: Thu, 17 Apr 2014 17:14:29 +0000 > From: James > To: Chris Anderson > > Chris Anderson,
> First of all, thank you for replying. I will explain in full detail about what happened.
> On March 10, 2014 I purchased the RTF Iris package with several added options. Total: $1,633.75. Order number: XXXXXXXXXX.
> 01) 1x 3DR Iris
02) 1x Iris Case
03) 1x Tarot T-2D Brushless Gimbal Kit for Iris
04) 1x 3DR Radio Set
05) 1x Iris Battery Pack
06) 1x GoPro Hero3+ Silver Edition
07) 2x APC Propellers 10X47 Push-Pull Set
> On April 8, 2014 everything arrived accept the Iris case. The case was on backorder. That was okay. Not a problem at all.
> I open up the package and all seemed well. After getting the Iris out of the box, first thing I noticed is the main antenna for the Iris was missing. I continued on
and pulled the Iris out to put the tall landing gear on. When I turned the Iris upside down, I noticed out of the eight screws that hold in the motors, only two were
actually tight. Two screws were missing and another screw fell out when I was packing it back up in the box to return it.
> The Iris case was due to arrive on April 10, 2014. It did. As soon as it arrived, I went to the UPS office and mailed it back unopened along with all the other
stuff. Two packages. All unused in the same condition I received them in.
> I mailed the two packages to the office in San Diego. 1470 Exposition Way Suite 140. They received both packages on April 14, 2014. Ruben ? signed for them.
> As of today, April 17, 2014 I have not heard anything from anyone about the packages. The only emails I have received have been them stating that, "we have sent you a new antenna and some screws." I do not have the Iris. I made that clear in my email to them. The holes were stripped on the Iris. Even if I had kept it, new screws wouldn't have worked to fix the problem.
> I did not ask for an RMA. I did not know what an RMA was until you replied. My mistake and I do apologize for that. However, I did return all of it as fast as
possible because I didn't want to miss any deadlines for warranties or returns. I returned all of it because I couldn't use or can't use any of it without all of it.
> I would really like to own an Iris and be a part of the 3DR family. I don't want to wait any longer either. It's already been one month and counting from the day I
placed my order. I think a reasonable amount of time to send me the same order would be by Thursday, April 24, 2014 or sooner. If that's not possible, I would like a
full refund.
> I am very sorry for bringing this problem to you. I know you are very busy and have more important things to tend to. I did try to call and send emails to no avail.
> You were my last option.
> James XXXXXXXX
> XXX-XXX-XXXX
Chris Anderson
Apr 17 (2 days ago)
to me
Thanks for the details and request. Have you sent the same to customer service? I'm many levels removed from that department, but if they have dropped the ball
somewhere I can pull together department heads and review the case. But CEO intervention is a course of last resort and only used in a case where there has been a
pretty serious failure of customer service. If that's necessary, please let me know, but otherwise all this should be sent to them.
-Chris
End Game
Seriously?
Can anyone at 3DR read? I told Chris in both emails that I can't get them on the phone and the only replies to my email are, "we are sending you a new antenna and a
bag of screws." In both emails to Chris, I clearly stated, "I do not have the Iris. I have already sent it back via UPS. It arrived there on April 14, 2014 at 8:49AM.
Ruben ? signed for it." I HAVE NOT HEARD ANYTHING SINCE. They don't answer the phone or my emails about the package or the problem with the Iris itself.
It's been one month and counting. If that's not a "FAILURE" in their customer support service, I don't know what is?! I also mention in my last email, he was the last
resort and I apologized for bothering him.
This morning the call was made to my credit card company. They lose, I lose. Sucks for all.
DJI, I'm coming home....
