100% at 55 degrees throttle travel
trident
Running a Storm drone with Naza M V2, Futaba 14sg. The system worked great until last upgrade when at takeoff she flipped in GPS when throttle at 55 degrees of travel. Destroyed two props and one broken arm. R&R the machine and now I can't figure out what is making it act this way. I have deleted all DJI references on my computer to a clean slate, reinstalled the driver and assistant software, did a compass swing, recalibrated the IMU, swapped the GPS puck with another I had and ran the software. In manual everything works normal. When I go to Att. or GPS I have idle and max pwr. This is the second crash this month; my S800 with Wookong made it to treetop and all motors quit. A very expensive month. Any ideas would be greatly appreciated. Helped a friend with his 450 with NAZA M and program ran fine and he has had no problems. Same computer.
Benjamin Kenobi
Easy? You call that easy?
After the upgrade did you re-calibrate the transmitter stick movements in the assistant? Are you sure the settings in the assistant software are correct? IMU correct direction selected and movements of channels in the assistant as per instructions.
How about your transmitter settings? Everything setup as it should?
Sorry, more questions. The truth is in the details.
