Av200
baker55
Does anyone have an AV200 or similar camera mount. I received mine today. The tilt works fine but the roll just rolls counterclockwise until it jams up. any thoughts? Shaun
Guest
first make sure your channel is neutral , make also sure refresh rate is set to 7
then remove the sprocket and move the potentiometer VERY slowly in the oposite direction where the mount is going to.
it will at some point slowly go backwards
FOX222
It's under the camera tab in settings. Mine is set to 4 due to my setup being different. Make sure the roll is not set to a poti. It should have a number around 125 to start.
Welcome DW Europe to MRF. Sounds like you know the Photohigher mounts well. There are quite a few of us on MRF with them and have all little issues. Any chance you could do a set up tutorial... pretty please.
PS
Where are you based?
Is that the new MKtools?
Does it work OK with the 82b firmware or is it only for the new one?
baker55
droidworx setup doesn't do a thing. The page that Fox222 I can get but the info on my page is only the bottom part of the page the rest doesnot load, but I will keep trying. I think that is the key. SM
FOX222
baker55
Do you get a warning window when you click the settings button?
baker55
Ok Now I have that screen you have. I have a Hexa what #'s should be the same and which different. Where do I go to find that info. Shaun
Hang on buddy...slow down.. can u post a screen shot of your camera tab in MKtools.. Its late over here but I will take a look and reply while u sleep!
