neilius
Hi Everyone, nice to meet you all!
I've been in RC for 15 years but about one month into quading and loving it! I hoped i could get a few questions answered if you dont mind?
My Graupner props turned up today. So im changing out the stock 8" DJI ones, not because i found them bad but mostly because as my payload has gone up to around 1.5Kg with all the fpv/camera stuff i wanted stiffer and more reliable props. I know these are the popular choice and i was delighted to see they were balanced out the box! Is that usually the case with these? Great quality.
Anyway, one thing i read is that the static thrust, size for size, of these props are lower that the DJIs. You can actually see their shape difference placing one on top of the DJI props, its quite different. That said, i was hoping that the 9x5 Graupners being an inch over all bigger that the DJI 8" would bring it back to about the same. Does that sound right..ish? It feels like its hovering in the same throttle position.
Also, are the any Naza gain adjustments i might need to make and if so which way? I presume id need to reduce gains slightly as the discs are bigger and far less likely to be prone to that spongy effect the plastic DJI props produced.
Many Thanks,
Neil
Many Thanks,
Neil
