I was wanting to know if it would be ok to run a 30c battery on a 30a esc?? I'm building a quad and don't know much about this type stuff.. I have read other forums but it all sounds like Chinese to me.. Can someone explain this in laymen terms?? Here is the info on the parts i will be using..
Motor
Motor
- Max. efficiency: 82%
- MAx. efficiency current: 7-16A(>75%)
- No load current/10V: 0.9A
- Current capacity: 16A/60s
- Internal Resistance: 150mohm
- Stator Dimensions: 22 * 10mm
- Shaft diameter: 3mm
- Recommended model weight: 200-600g
- Recommended prop without gearbox: APC 7*6, APC 8*3.8, APC 9*4.5, APC 10*5
- Item size: 3 * 4.8cm (Diameter * Length)
- Item weight: 43g
- High rate PWM
- Low resistence
- Sixteen cells Max (with BEC disabled)
- User programmable brake
- Low voltage auto setting based on battery
- Throttle range self-adjusting
- Soft start ramp up
- Auto motor cutoff with reset
- Runs motor in forward or reverse
- Safe power arming program ensures motor will not run accidentally after turn on
- Low torque start
- Auto shut down when signal is lost
- Constant Current: 30A
- Input Volt: 6V - 12V
- Max Current: 40A
- Low-Voltage Cutoff: Auto detect and set
- Size: 56mm x 24mm x 8.5mm
- Weight: 26g( Net Weight)
- Battery
- 11.1V 2200mAh 30C 3s Lipo Battery Pack
