Hello !
I have 2 WKM kopter and at each the same problem :
Temp inside : 20 degrees centigrade.
Temp outside : 1 degree centigrade.
When I take the copter from inside to outside everything is ok. No white flashes and I can fly.
After the first fly the copter stands still outside for appr. 10 minutes without LIPO connected.
Then I connect the lipo and the kopter starts to flash with 3 white flashes.
They do not go away.
Then when I start the motors liftoff is not possible because the copter tries to flip on its top.
The I take the kopter back inside.
After appr. 10 minutes the white flashes are gone.
This is a very big problem !
And it happens with both WKM kopter the same way !
Fritz
Fritz
