Ferdinandk
Which firmware do you reccommend for the S800. Also Pan, Tilt, Mode and Shutter are all of them just switchs and Sliders. Pan and tilt would have to be knobs or sliders correct the others on switchs does it all have to be connected or can you just use tilt mode and shutter.
I cannot recommend a firmware, I am using 5.08 (but I have not tried anything newer) I have pan and tilt on sliders, shutter is a 2-pos switch, mode a 2-pos switch.
Update...
Got single operator hooked up with pan and tilt on slider switchs. Roll port not in use or hooked up. Coud this be why camera always sits at a slight angle?
I have not hooked z15 and nex7 to my s800 yet. The main reason is that I do not want to invest (yet) for a second tx and rx to control the camera. I have only one channel left on my tx. Is it possible to somehow use this channel to set the z15 in fpv mode and just leave other functions out? I could turn on the camera manually and let the camera point the same direction as the nose of the aircraft. So is it possible to leave all channels disconnected except the mode channel? Does z15 stabilize the camera in such situation?
