I believe these are similar to the motors you are looking for.
http://www.multirotor.co/product_info.php?cPath=2_36_40&products_id=95
Use
http://www.ecalc.ch/xcoptercalc_e.htm
to see what props and lipos you need.
I just tryed them out on my Skyjib and 5s. The wight is 7,5 kg.
You will need some 60 amp ESC on it.
But great engines.
These kopter worx motors or KW 8 motors are Tiger motors, so why would sacrifice axis for tigers... I think almost everybody in here know axis and swear buy them, hope you have done your research... I was thinking the same thing cuz I'm a noobie to Multis, but if everybody and there Mom runs Axis there might be a good reason to keep running them unless you want to likt heavier in witch case there are AXI 2826.
I'm not going to lie I was considering them, but not because they they are better, but because I'm running a Cinestar Frame, the Cinestar motor plate is based around Tiger motors or Quadrocopter 3328, witch is a rebranded tiger with some slight mods to make it more efficient I guess. It's all advertisement.
Tryed and true wins the day in my opinion.
Heliguy yes Tiger makes them for us, but there is difference, some modifications, differente RPM, ...
Try it and compare them with AXI and at the end u will see what u will use.
U will be surprised how many AXI users switched to our KW8 not to mention our KW10 new killers![]()
Hi, I think that the axi motors are great just that I've had this misadventure and it bothered me a lot.
The choice falls on KW8 value for "hope" price because it should take 9 units, and having a diameter equal to the axi advantage of the same dish motor 40mm.
One thing I really do not understand, when you put the KW10 because you have changed the specifications of trust engine KW8 from 3200gr to 2700gr now and Kw10 now from 3000 to 3300gr.
thanks
Have a nice day.
http://www.youtube.com/watch?v=7DzwX_fLNxM&list=UUU5NAEHNWV5hE9ju7QQJARg&index=2&feature=plcp
kw8 are 3.3 kg thrust too!
thanks
Have a nice day.
Well since diferent result is given on diferent prop. Kw10 can go up to 4kg with 17inch.
I hope we can next time putt same videos with props so we can put the info under specification.
Easyer for buyers to decide on props then.
