Futaba to WKM latency?
I have a Futaba 8fg with S-BUS 6208SB to a WKM. I find in the WKM assistance shows about a long delay between toggling OFF, POI, HOME.. is this normal? I am wondering because, when I toggle new HOME POINT or new POI HOME POINT while it is in the air, should I be toggling it fast as assumed, or should I go with the speed that shows up in the WKM Assistances?
delay is about 1-2 secs.. between each mode.
Thanks again,
KS
DaveM
Just toggle it fast as you would to calibrate, it works fine.
I have the same Tx and Rx, and also get the delayed response in the assistant.
