Flamewheel F550 Hard case?
T
trevlan
Guest
I'd like to find one too, lol. but to also hold my gimbal and batteries ETC.
im guessing in the end a custom one is the only way.
chopper
I am not sure if you can escape bulky, but I do have two pelican cases for my gear and was considering one for my 550 also. Maybe something like this. Deep enough that if you had a gimbal underneath it has room for that, and other gear. http://pelican.com/cases_detail.php?Case=1630. The 1690 may also work, the 1630 could be tight.
I am sure pelicans are worth the money but the prices are outrageous!!
Closest fitting for F550 and reasonable priced cases I have found are soft cases used for portable message tables. Range from 25" -32", 6" deep and some with extra pockets. Most under $100. Not so great for the airlines but may work great for local transport.
Exampleshttp://www.amazon.com/gp/aw/d/B000OZT4DA/ref=aw_d_iv_hpc?is=l&vs=1
Image:http://www.google.com/search?q=port...6AI8TXigLt24DgAg&ved=0CHIQsAQ&biw=360&bih=640
Image: http://www.google.com/search?q=port...6AI8TXigLt24DgAg&ved=0CHIQsAQ&biw=360&bih=640
T
trevlan
Guest
Oh thanks for the links. Yes pelican expensive but your right it might be the best option.
I'm going to check them out.
gsafety
gsafety
Still a work in progress but this is the Pelican 1690 with 'pick and pluck' foam. Picked it up for $525 here in Edmonton.
Its turned out to be a pretty good buy as I am able to fit the machine with Photoship one landing gear and Zenmuse in with out disassembly + all my FPV gear and chargers for everything (including Hyperion EOS0720i charger) Only the GPS post needs to be removed.
View attachment 16512View attachment 16513View attachment 16514
gmahan3
I have the F550 with the heavy lift conversion. It looks like with a tape measure I am coming in at 26 1/2 inches across. I cannot find a case that they shipped worthy to accommodate my set up. The Pelican website says the 1690 has an interior dimension of 30" x 25"
GSaftey what is exactly accurate?
JoeBob
Elevation via Flatulation
The 1690 is 30.75 x 26 inches (hard edge to hard edge) at the lid closure. It tapers slightly the deeper you go.
Got mine slightly used on eBay for $325.
gmahan3
I have the motor extension plates to run up to 12" props these pates add about 2" in both sides. Making my overall diameter ~26.5" and can't fit into precut foam... unfortunately.
Yeah I have used those as well but changed to the Aluminium arms. I ended up building my own case for transport. However I do believe i-drone will start carrying those boxes to suit 550's with the arm extensions. might be worth emailing them and asking
gmahan3
Thanks AboveAll. I shot them a message. What are you thoughts on the aluminum arms? I'm assuming they are the ones from readymade. Can you still run a 11x5 prop?
JoeBob
Here's my Pelican 1690. I was thinking about arm extensions when I bought it.
View attachment 16550 View attachment 16549
I'll only have an inch of padding on the edges, so hopefully the frame will hold it off the walls from the middle.
I haven't cut the foam yet because I'm considering putting a Disco Pro underneath it.
Just ignore that mud on the props. I have no idea how that got there..........
gmahan3
I found a 1690 on Amazon for a good deal. Once it arrives I'll post up my results.
Love the aluminum arms. Little pricey but getting great results. I run mine with 11x5 props and are wanting to try 12x5 which will fit.
JoeBob
