ESC32 with NAZA
Does one of you already have experience with the ECS32 with NAZA ?
Have everything setup TBS Naza ESC32, ESC run with servo tester no problem, but i can't get them to start up with the NAZA.
Melody comes but the set beep doesnt come and the LEDs on the ESCs keep on blinking red.
Do I have to change anything in the PWM settings for the ESC32 to get this running.
View attachment 5657View attachment 5658View attachment 5659
Thanks !
mailman35
my one naza (post gps fw upgrade) decided it didnt want to control 2 of the 4 esc's that i have( hobbywing 30a) i downgraded to the previous fw and assistant and had no probems cnc'ing or flying, yet an upgrade back to the latest code, and it breaks it again.
it sounds like it might just be a dji feature, forcing you in to their own parts. IMHO>
Safetac
Im running 8 x esc32 on Cinestar with Wookong only changed motor start voltage to 1.8 the Axi motor were a bit lazy on startup.
Changed motor current to 40 amps with good heatsinks .
All motors arm on startup using 4S with ESC32 onboard reg PWM settings as default.
thanks guys will try some different firmwares but doubt it will take care of the problem, have a WKM not really in use at the moment, gonna try that also.
Voris
Also noticed the laziness of the axis starting up on my TBS, gonna change the voltage thanks !
