Huge Size OctoCopter 8-axis Full 3K Carbon Fiber 3.5Kg Payload with Wookong WK-M GPS
Huge Size OctoCopter 8-axis Full 3K Carbon Fiber 3.5Kg Payload with Wookong WK-M GPS Multi-Rotor Stabilization Autopilot System
Freeshipping from http://www.soodohobby.com
View attachment 5616View attachment 5621View attachment 5622View attachment 5623View attachment 5617View attachment 5618View attachment 5619
www.soodohobby.com
Flying Performance, pls follow us on the youtube: http://www.youtube.com/watch?v=dVzJKWKvg...e=youtu.be
Configuration:
Full 3K 100% Carbon Fiber Materials for frame, tube, high landing gear, propellers
Metal CNC connectors parts
16'' size 3K carbon Fiber propellers (8pcs)
5038 420KV Disc Brushless Motor (8pcs)
60A Hobbywing ESC(8pcs)
Flight Controller: DJI WooKong-M GPS Complete Flight Control system for Multi-rotor stabiliation autopilot system
Specification:
Axis: 8
Motor shaft distance: 120cm
Payload: 3.5kg
Flying time: According to the battery
Package Included:
Frame,8pcs Disc brushless motor, 8pcs hobbywing 60A ESC, 8pcs 16''Carbon Fiber, DJI WooKong-M GPS Complete Flight Control system for Multi-rotor stabiliation autopilot system
Suggested:
6S 8000mah-12000mah Lipo battery
WFT09SII 9ch WFLY Radio Set
5.8G 400mw FPV wireless transmission
We accept the custom made according to different requirements. More technical information, you can send us the mail: sales@soodohobby.com
Very good for the aerial photography for the high paylaod.
<!-- start: postbit_attachments -->
  • Huge-Size-OctoCopter-8-axis-Full-3K-Carbon-Fiber-3-5Kg-Payload-with-Wookong-WK-M-GPS-Multi-Rotor.jpg
rsun
Remove the WKM and tell me where to get a carbon octo at $2200 with that big engine, carbon props and 60 amp ESC ....
Easy, a number of the guys on Rcgroups have done it
Check Jab, he was one of the 1st, Ive followed and so have others
http://www.rcgroups.com/forums/showthread.php?t=1669877&page=5
His Maiden, using 300w motors as below, same props below, carbon frame below
http://www.youtube.com/watch?v=hKMvQokZp54&feature=player_embedded
Get yourself an octo frame either GF or Carbon
GF $250
http://www.goodluckbuy.com/professi...copter-frame-set-kit-700-950mm-wheelbase.html
Carbon $500
Carbon $460
http://www.omgfly.com/index.php?main_page=product_info&cPath=1_41&products_id=652
8 Large disc motors
300W $39 each (I personally use these on my own Rusty frame octo Im currently building)
http://www.himodel.com/electric/HL_...otor_for_Quadcopter_Multi-rotor_Aircraft.html
650W $66 each
http://www.himodel.com/electric/HL_...6-8_rotors_5-10kg_flight_weight_Aircraft.html
8 ESC's
I use these $16 each 3s-6s
http://www.hobbyking.com/hobbyking/...RUST_45A_SBEC_Brushless_Speed_Controller.html
I also have these but there only 4s
SimonK Firmware pre flashed, 30a
http://www.rctimer.com/index.php?gOo=goods_details.dwt&goodsid=779&productname=
15x5.5 props, 2 sets, these can bolt directly onto the HL line of disc motors
http://www.rctimer.com/index.php?gOo=goods_details.dwt&goodsid=747&productname=
Use a car audio power distribution block for your wiring and your all done!
Total build cost between $800 to $1000 using the 300w motors which is more then enough to haul a large DSLR setup, Im building mine around Rustys UAP1 $750 total, dont need carbon bling to fly
