Scorpion motors on Cinestar?
ChrisViperM
Lanzar, this is Scorpion
http://www.scorpionsystem.com/about/history/
Ben
They are of top quality and even back it up with a 2-year warranty...but they are pricy. I only know them from RC-Singlerotor helis and have two of them. Lots of competition pilots are using them for their power and reliabilty.:
http://www.youtube.com/watch?v=GSoYfLXsRIg
They even have kits to make the motor to your own specs:
http://www.scorpionsystem.com/catalog/bl_motor_kits/
But as you know, you would have to look for a motor with low kv. I actually should have a look into this motors for Multirotor use. Maybe you write them a short email with what you need, they normally have a very good customer support.
And thanks again for your tutorials....
Chris
I'm looking at the Scorpion SII-3026-710 --- if the shaft was shorter it could do the trick. I could use them to lift an Epic with my Cinestar without a problem.
ghaynes
Benjamin
Interesting. But keep in mind that the weight is higher than the KW8's and there is no 6mm prop shaft adapter (says it has a 5mm) which would add to the cost. KW8 would be about $ 117 each. Matjaz earlier told me they are 710Kv.
ChrisViperM
The long shaft is not a problem. With a Dremel tool and a cutting disk you fix 8 motors in 15 - 20 minutes. The higher quality props come mostly with adaptors to fit a 5 mm shaft...or take one of the mentioned prop shaft adaptes.
Chris
The KW8 motors have a good rep. It is likely that I'll go with those.
As for the Scorpions, the prop adapter fits on the 5mm shaft and has a 6mm threaded shaft.
The Scorpions can handle a bit more electricity.
The symmetrical spacing of the motor mount will be an issue too with the Scorpions - I'd have to get some fabricated. Could be some trouble.
Benjamin
Well i like to check on other stuff also. Well KW8 are good and proven trustworthy. But i am always curius.
Does it make sense to haul a Red Epic with a Cinestar8 with 8 KW8 motors? I'd be using the Cinestar 3 axis gimbal. On eCalc, I can make it work. Does it make sense in the real world?
Here are my results in eCalc with the KW8 motors on a CS8 with an Epic camera.
you dont get worried when you see the red text saying it is over the rated current?
Yeah, i wonder what changes, if any, kopterworx has Tiger do to those to make the specs slightly different.
No worries, that's barely over the limit. I never use maximum throttle. (knock on wood)
Lanzar
Only thing i would change is 5s battery since much better performance. Othervise looks ok. And weight is not ok.
Cinestar alone with bateries is 7kg easy with mount. +4kg red so add 4kg on the top line. And full throtle can be fatal ofc.
check my fast calculation, hope no mistakes made in it.
Lanzar, thanks for running the numbers for me.
Please note that I ran it at 7kg "without drive" and my AUW is over 11kg. So we were using very similar numbers, but in a different way. Should I be concerned about full throttle killing the motors? At the moment, I'm not, because I don't use full throttle.
Thanks for your help!
remyd
APC12 x 6 using 59 amps for 3400g of thrust be careful with your choice of ESC's
<tbody>
</tbody>
